AlfaODB and DPF Regen
jbehler75
Hi, new to this forum and I have a 2020 Ram Ecodiesel and I am using AflaODB with ODBLink MX+.
Has any used this to check DPF level or to force a regen?
1,002
350
I have forced regen. Pretty sure I also checked dpf level but that was years ago now
1,002
350
You may need a security gateway bypass since it’s newer. Cannot remember the technical term for it lol
382
135
I have used my Alfa and the OBDLink MX to force regen a couple of times, my 2500 RAM and my wife's Jeep Eco. I have the PC version and on the Plotted Data selection you can select the processes that you want to view. I believe around tab 11 there is a urea level although it is MM not percent of tank full. The Regen function is under the Active Diagnosis selection.
Good Luck
