Catch Can
turbo16
I've been looking for a clean install for a catch can, haven't found what I wanted so I designed my own system. So I started with the Mann & Hummel Pro Vent 200 catch can and designed my own bracket that installs to the power brake booster. This is a 3D printed bracket made from ASA material that works well for automotive applications. I have a drain tube installed with a petcock attached to easily drain the oil.
My first test drive I through a P04DB code (Crankcase Ventilation Disconnected), apparently their was to much restriction in the Pro Vent 200 can. So I opened the can and removed the cloth wrap around the filter to reduce the air flow restrictions and reassembled.
Low and behold it worked, no more P04DB codes! I ended up with a clean factory look install for my catch can.
