CFT turbo muff/baffle delete
Milvetmac
69
I got the delete installed today and used a set of constant pressure clamps from turbo smart and it had an initial positive increase in throttle response and very slight torque whine to 30mph then BAM blew the inter oiled side hose off with enough force to almost dislodge the hose from the intercooler... (at factory bolt torque spec), from there I bumped the torque spec up 5lbs at a time until it literally wouldn’t tighten anymore and it’s still blowing off; so A) the Powdercoating is making it too slick
B) the bead roll isn’t tall/aggressive enough
C) combination of the two
so after spending a solid hour fabricating a mount to hold the hose/piping up solid since the factory mount wouldn’t work anymore, and however long it took to pull it all out/re install multiple times I’m pretty disappointed I had to go back to the oem baffle After all that. Spent money and a lot of wasted time with no solution
Foxracingx02
37
Best thing you could do is replace the factory piping with an aftermarket setup, the trouble is at the bottom of the baffle it makes a hard turn, so when pressure hits it pushes into that hard bend. So try to double clamp it, If it's blowing off at the intercooler replace the clamp and tighten the hell out of it, it poly plastic so it's not going to break makes sure the hose is pushed on past where your clamp is at, or add a second clamp,. I use 1.50 clamps from rual king and they work awsome @ 35psi,. But if you have aluminum piping don't tighten too much or it will bend the pipe and leak, there is a fine line, I've found it a few times :)
Milvetmac
69
awesome, thanks for the info! i am probably going to just go with aftermarket set up at this point im tired of "trying things" to make it work and cft doesnt want to respond or give me a solution; so off to the bin it goes
