CODE P0191 DODGE RAM 1500 ECODIESEL YEAR 2015
MIGUELSARMIENTO77
CÓDIGO DE PROBLEMA DE BUENAS NOCHES P0191 PERRO RAM AÑO 2015 SENSOR DE PRESIÓN DE COMBUSTIBLE
ESTE SENSOR SE REEMPLAZA Y EL CAMIÓN EN LOS SIGUIENTES 4 DÍAS SE DEVUELVE CON EL MISMO CÓDIGO.
Para saber si alguien DICHOS FLAS CAMIONES SE REQUIERE EN ECM .. O alguien tenía un problema en esta mismo código.
717
If you can translate its the pressure sensor wiring connection. The sensor rarely fails. check the electronic PRV, on occasion the FCA/FPR.
MIGUELSARMIENTO77
Good morning have a problem with a Dodge Ram 2015 ECODIESEL presents P0191 code the vehicle is replaced the FPS sensor but after a few miles reappears the same code anyone know if these cases codes to the replace the sensor is required any special cleaning enclaustrado ECM or to reroll the same code thank you very much.
MIGUELSARMIENTO77
Sorry, we only support English here.
good morning have a problem with a Dodge Ram 2015 ECODIESEL presents P0191 code the vehicle is replaced the FPS sensor but after a few miles reappears the same code anyone know if these cases codes to the replace the sensor is required any special cleaning enclaustrado ECM or to reroll the same code thank you very much
717
NO. Post #3, The electronic PRV will need to be inspected and re-installed, the FCA may need replacing. The rail pressure is not within mapping thats why its triggering the code.
