Cold Weather Requirements
BJE
Bought my 2016 in FL.... did not come with a radiator cover. I have since moved to Maine, and this will be my first winter up north with the truck....I did purchase the block heater cord. Two questions- at what temperature should the block heater start to be used?...and should I get a radiator cover?
Thanks.
4,358
1,155
Thanks.
I don't have extreme cold weather here in TN, but I've had single digit nights and never had a problem.. but, I would just put it on a timer to run about 2 hours before you leave and call it day.
Lou
26
The block heater is being nice to your truck, until it is sub zero it's not really needed.
It does make for easier starts and faster warmups.
The radiator cover should be used most of the winter, if it's under 45 deg.F unless you are towing heavy it will not overheat. It will come to temperature faster and run better, use less fuel, and the heater will work better. Also people have had the inter cooler freeze up while running in snow storms.
Every thing on the truck works better when it's warmer.
726
45deg IMO is way to warm/hot for that cover, its simply a myth that won't die, You are going to raise intake temps 50-150deg ,this will cost you mileage and engine life , Yes heat is important but subjecting it to excessive heat is damaging, The 3.0 already has a heat problem many plenums have fail due to excessive heat. I would NOT recommend that cover until -0 temps.
IC freeze ups are unrelated to the WF, Some snow has found it way into intake filter box, the WF would stop that.
Lou
26
I find that the winter cover helps my mileage considerable, and I have seen no high temp issues.
