Gossman78
- Oct 2, 2016
- 48
- 8
- 2015
Stock 2015 EcoDiesel: On the Coolant Recovery Tank/Coolant Reservoir there is a hose that exits from the bottom of the tank, makes a turn to the passenger side and runs across a small portion of the radiator and then runs down the radiator on the passenger side. It ends in an apparent open hose right above the termination of the lower radiator hose to the radiator. What is the purpose of this hose? Additionally, is there a check valve for over pressurization between the hose and tank connection?
I took the truck to the dealer for smell of coolant. They told me it was a weeping bypass tube. So, of course I replaced the lower radiator hose that connect the top of the motor to the bottom of the radiator and 'T's' into the tank. As i started to fill up the tank after a job done this 'lower hose' started leaking coolant onto the top of the lower radiator hose where it terminates to the radiator. Then it stopped. I filled up the remainder of the way put the cap on and warmed up the truck. No issues. Then I drove home. Truck got to a temp of about 185F and when I popped the hood to check when home the same hose had dribbled a bit of coolant onto the top of the radiator hose.
Anyone got and thoughts? Anyone know a replacement part number MOPAR?
