Crank but no start
West Via
Hello! Hoping for some help!
2015 1500 Big Horn Ecodiesel
Several days ago it cranked but wouldn’t start a couple times and then started and ran a few days with no problems. Then when accelerating up a hill it went to downshift and BAAM... died and coasted to the shoulder. I panicked and cleared any codes hoping it would start but no luck.
So it cranks but won’t start.
I changed the fuel filter and there is fuel pumping TO the HPFP. It will sputter if I spray starting fluid in the intake and the HPFP seems like whines or whatever when the key is turned on I just don’t know how to test it correctly or where else to look. I read on some engines there’s sensors that tell it when to pump?
Only codes I can get now are P061c and P062b
Thanks for any help!
717
Its either the big connection under the dash Disconnect- Reconnect or its the Crank sensor failure, You hope its Not the cranks sensor because the trans needs to be removed to change it out.
West Via
Thanks for the quick response! That’ll give me a starting point checking the crank sensor. I’m really hoping it’s not the HPFP or the like... thanks again!
I'm with TC on this one. Sounds like a crankshaft position sensor based on the codes.
717
Its unlikely to be CP4 or fuel related.
brianjonesphoto
Sorry to revive this thread but I'm getting intermittent P062B codes that usually come up at a cold start. What was the resolution to your problem?
Thanks.
