Electronic throttle sensor
Jmshouse1887
Hey im new to this forum. I recently bought a 2014 ED. When driving today i had the cruise set at 70 and it flashed low battery voltage and kicked outta cruise control. About two minutes later it gave me the electronic throttle sensor alarm and went into limp mode. I had zero peddal pressure but truck would run about 25 mph and 1800 rpms(even going down hill at a very steep grade). At idle it sits about the same rpms. Any clue on the issue? Ive been reading through this forum for the past few hours and it seems like everyone having the same issues have different outcomes. Any help would be much appreciated. Thanks and Happy Thanksgiving!
380
133
Wow, multiple possibilities. First and foremost as long as the Electronic Throttle System Service message is displayed you will be in Limp Home Mode and your Regen Cycles will be STOPPED, thus filling your Diesel Particulate Filter creating another problem, so do not drive the vehicle. Now you will need to explore the Low Battery Voltage issue, first stop, check battery, type, voltage, age. OEM is Absorbed Glass Mat technology at 800CCA, then how old is the battery, at end of useful life. The alternator will require a modern voltage tester and a good battery, do not use an older style Pile Load Tester as the FCA system does not like the load. Once you clear the Electronic Throttle code you can determine if you can handle the rest of the issues or go to a reputable shop. you will be able to drive once the code is cleared.
Good Luck.
Jmshouse1887
Good Luck.
Thanks for the response! Took the truck to the dealership today and they said it was a bad PCM.
380
133
PCM is the worst case scenario, self help is the cheap, easy, items first to eliminate the big bad ones that only the dealer or reputable shop can handle.
Good Luck.
