Hello
West
Hello everyone i'm a new member to the forum from Canada. 2016 Ram Eco Big Horn pulling a Cougar 25BHS 5er
JohnnyMac
75
23
Welcome aboard eh' :) Lots of good info here. Good looking 5er, how's it pull? What's the dry weight on that baby.
West
dry weight 6950 lbs pin weight 1375 lbs pulls great installed rear load lifter air bags just to make sure i stall level.
JohnnyMac
75
23
Great to hear! I've been perusing tows and wasn't sure what I should be using as a max dry weight. Apparently 6950 is good.
West
yes but but the pin weight puts me over my gvwr. all my investigation before i bought my trailer i found almost every 1/2 ton was over the weight gas or diesel. So far mine has been fine. i pulled a travel trailer before that was over 7000 lbs.
JohnnyMac
75
23
I think the main reason that the EcoD has the limits it does, is because of the inferior cooling system, and it will capably haul more, but you have to be careful with long uphills so you don't overheat it. The new 2020 EcoD does have a little more HP/TQ, but it's got a much better cooling system so it's good for over 12k.
2015Ram1500
45
Any ideas for upgrades on the cooling system. I have a 2015 w/3.55 gears. I want to pull a fith wheel like yours😎
West
that was going to be my next post. i have not changed anything on the cooling system yet. That's my winter project to do the research.
283
wow looks like u need a 2500 to pull that legally welcome 2 the group
