Hi Keep on trucking
BruceRBC
I’ve been registered for a while and now I’m getting on board. I have a 2016 Outdoorsman crew cab with over 247k km. Deleted and running strong doing a minimum of 100km a day m-f and 400km on the weekends.
I have some warning lights come in for ABS and trailer brakes need servicing. I’ll be cruising around the forums to find what I need.
KINGKOTA78
Could check the wheel spin sensor and ensure they aren’t damaged and are pushed all the way into the hub. A medium size of hose pilers are great tool for removing and installing the sensor. I’ve also seen them get dirty with brake dust and not be able to read the tone ring. If they are dirty just clean them off with some brake cleaner and a rag. Is the trailer brake light on continuously or only when a trailer is hook up ?
BruceRBC
BruceRBC
Just ABS and traction control lights on. The service trailer brake system and service antilock brake system are the stored messages that come up when I start.
thanks for info on speed sensor I thought the hub had to come off. I will check them the next time it’s in the garage.
KINGKOTA78
It’s been a minute since I’ve done one on a ram but if I remember right you can take the tire off and may have to loose the dust cover to get to it. Let me know if it works out for you or not ! I don’t know if you hooked a scanner up to the truck or not yet but it should tell you what wheel is not reading if that is the issue.
