Hi my name Blake I just bought a 2016 Laramie eco diesel
barkerblake82
I want to get it lifted 6” but don’t know what all I need to order along with it. I’ve been told I’d have to replace my drive shaft? I just wanna get it done we and over with but nobody seems to know except les schwab and they want to much $
1,068
367
Welcome! Do you have air ride? I know those tend to come with more headache but the 6” kit from anywhere usually states what’s required after a lift is installed
barkerblake82
It does not have air ride. I was told I would need to replace my front drive shaft
Hapahaole
32
At 6" I don't think you need to replace the front driveshaft although it will be stressed at the angle it will be running. I'm sure some others will chime in.
barkerblake82
Thank you guys for your advice and feedback I ordered a 6 inch rough country lift kit it says that I will be able to run 37’s if I run 20”x9” wide wheels And 37” x 12.5” wide tires. I’m not sure what size wheel spacers I’m going to need but I will figure it out when the time comes I suppose again thank you
1,068
367
I have a 2” leveling kit, with a 1.5” body lift and I was running 35/1250r20 tires on stock wheels with a 1.5” whee spacer. It was enough to fill the fenders with slight tire rub. I would look look at www.customwheeloffset.com for ideas on what combo tire and wheel offset for your taste!
