Hi
Jarhead72
I have a 2018 eco diesel bought used around 25000 mi. Got to 43000 and fuel pump died destroying everything in path. Fix is $9000 and Chrysler with help at all..
717
It should be covered under the 5/100K Miles Warranty , Is Fiat/Dealer claiming contamination?
Jarhead72
Dealer says 36000 so no go. Power train coverage no go either. Says unless engine, trans or rear end fluid goes thru the component it won't be covered. Comprehensive Insurance say no too because fuel test says no contamination. Probable was the last tank I ran thru it was bad. I have been traveling a little.
717
Why Not on Powertrain? that fuel Injection system is covered in 5/100
717
Dealer Wrong, Are you in Canada?
717
How Long It Lasts
The Powertrain Limited Warranty lasts for up to 5 years
or 100,000 miles on the odometer, whichever occurs
first, calculated from the start date of the Basic Limited
Warranty, as set forth in Section 2.1(E).
Diesel Engine:
Cylinder block and all internal parts; cylinder head assemblies;
core plugs; fuel injection pump and injectors; intake
and exhaust manifolds; oil pan; oil pump; timing gear
drive belts and/or chains and cover; turbocharger housing
and internal parts; valve covers; water pump and housing;
seals and gaskets for listed components; glow plugs and all
sensors.
717
Post #9 right out of the Diesel Supplement.
717
My guess Dealer/Fiat claiming contamination.
Jarhead72
How Long It Lasts
Diesel Engine:
sensors.
Thanks TC where can I get a copy if that information. Is it on the Ram website somewhere?
Jarhead72
Just had a long conversation with Chrysler. I found the page in the powertrain warranty that says the fuel pump is covered. When I called them out on it I ended up with a long phone session where they transferred me from "expert" to another all of which couldn't explain why the powertrain warranty won't pay for repairs. Finally after a hour they called the dealer and came back saying the emissions delete voided the warranty.
717
So its a deleted Truck? You NEVER mentioned it was deleted, So YOU have NO case.
