How to replace Front air shock replacement
Grabyfam
I want to replace my front air ride shocks on my 2015 Ram Ecodiesel. I would like to buy the Arnott shocks.
so the question is to replace can you lower the air ride to entry/exit thus emptying the air out of the shocks?
Then replace them while it is still in that mode/ position? Would that work without having to recharge the system?
My thoughts are this should work. And why not?
1,265
346
There's an air line. No coil spring so once the line is off and the strut is unbolted you just compress it and pull it out.
