Is there a cheaper alternative to DEF?
coztex
Hello, is there a cheaper alternative to DEF? Can we use just water or maybe urine?
Thanks!
680
2013-16 Can run 80% distilled water 20% DEF..SO That's 2 gallons distilled water 1 gallon . I ran that ratio the entire four years of ownership of my 2015 Once I got a rational code but I just added a little more DEF. Deleted the code and never returned.
DATA
42
Did you run that in the winter to?
680
Yes...MN winter..
680
ALL DEF FREEZES AT 12F...the system is designed to start thawing at 26F ..so No Problem in any of my Diesels. MANY ARE running that ratio..2018 + needs 2 Gallons DEF to 1 Gallon distilled water..
680
2 gallons distilled water to 1 gallon DEF. IF SOME SOME ODD reason you trigger a rational code just at al little more DEF and drive a few miles it will dissappear.
