New kid here…. DEF problems
TJParker
Joined
Apr 4, 2022
Messages
Hey all I am new to the eco-diesel world. I just got that warning light that the engine will not restart after 200 miles because of the DEF. I know someone has had this issue any recommendations would be welcomed and appreciated
Welcome... assuming it's full you'll likely have some trouble codes stored that will help guide to what the problem might be..
I did take it to the dealership and I’m just waiting for them to tell me what the hell is going on with it.
Certified DEF is 33% urea, 67% water. As it ages or gets contaminated, it's potency drops. When it drops to 22% urea you will get an alarm (2016+ trucks). If it's not a DEF condition problem, it could be a clogged injector or pump, etc. Good that you have the dealer looking at it.
Thank you sir
Well i ran into the 'Truck will not start in XXkm, see dealer' .
I really did not want to take truck to dealer because it is always a $500 bill even when they do not do anything.
I had the P05ED - Reductant Heater Control Module Supply Voltage, and P2BA9 - NOx Exceedence - Insufficient Reagent Quality.
I ran it down to 50km before i gave in and took to dealer. They called me after an hour of service and needed a couple more hours to chase the wires and try to find problem. Never did really find the exact cause but said i need to spend $6,500 to replace DPF cause it is cracked, Need to replace DEF Heater Control Module and wire harness too. To boot, they can't get parts for over a month!!
I told them to just leave truck and i will come get it. That was yesterday. And bill was $450 for doing nothing!!!!
Truck has a legal GDE tune on it that i reflash to original before taking to dealer.
As soon as i got home i went online and bought a delete tune and DPF delete exhaust pipe. Should be here next week sometime.
So now i have this legal non delete tune from GDE that i don't need.
Anyway, after i got truck home i only have 19km before it will not start. Pisses me off, the mechanic said truck will be a paper weight if i go past the set km. FAK!
So i get my ALFAobd hooked up to truck and was looking through all the settings... Well shit there is a setting that is under engine, start procedure is 'Write Odometer' . I think to myself 'can i backup the odometer so truck has less km?' Thats not what it does but i have 138,648 km on truck and only 19km more till it wont start. So i write the odometer to 138,400 i think it was. This does not actually change the km on the odometer because the odometer still reads 138,648 km, but when I restart the truck low and behold i now have 220km before it will not start. So i figure if i can go back that far why not go even farther. I went back and wrote the odometer to 138,000km so should have 650 km before will not start right? Nope i restart truck and the 'will not start message is gone'!!!
I figured i better take truck on a 25km trip and bring it back to my garage in case it will not start still after 19km.
Go for a 22km ride and bring it back home, shut it off. Now heart was beating a bit in case damn thing wouldn't start but shit it fired right up and still no 'see dealer in XXkm or truck won't start' message.
Now i can at least drive the damn truck till the delete tune gets here!!
I probably won't go too far from home and leave it running if i stop any where till i am sure that it will keep starting but for now it seems like a temporary fix.
Hopefully i won't do any damage to truck but i am some what happy that i can give the dealership a big middle finger.
Looks like you stumbled on to a great band-aid for the dreaded DEF message. Thanks for sharing and hoping it keeps you operational.
Well, today when i went to start truck it said it wouldn't start, service def, see dealer. Damn. I got around it by writing scr reset def fluid level then i wrote scr extend mileage w active fault. It gave me 80 km again before it won't restart. Lol
I wrote the odemeter back to 138000 km again and do not get the message 'will not start in xxkm, service def see dealer'.
I gotta make sure to have my ALFA obd with me when i go for a ride just in case. Can't wait to get the new delete pipe and tune.
Next time try this, it worked for me. I now always carry a jumper wire.
Pull out the starter relay, and put the key in the RUN position.
Take a short piece of wire and jump (in the fuse box) between
where pins 30 and 87 on the relay would go (if it's labeled 1-2-
3-5, jump between pins 3 & 5). Engine will start right up.
This shows pins 30 & 87
I do remember reading about this somewhere, good to know and the pictures really help.
I will cut a piece of wire and leave in glove box just in case. Thanks for the tip!
