Oil in my coolant reserve tank
Christian21
hello ! I have a 2014 ecodiesel ram. It has 90k miles right now and I noticed it has oil in the coolant reservoir tank. I have read on the internet pages that it has an oil cooler. I would like to know if this is covered by a manufacturer's warranty? If someone happened to him and can tell me if the warranty covered it or what I can do, I would appreciate it!
876
431
Probably a bad engine oil cooler. If not that, a blown head gasket.
694
likely the Coolant exchanger on Drivers side engine, Unless you have extended Warranty its not covered, and can Destroy the rotating mass of engine (Generally if cot early and fixed its avoidable) , HOAT/ OAT coolant mixed with Engine lube with CAL creates micro sand balls, Some early engines were replaced By Fiat when this happened 2014-15, When it was happening by the 100+ Fiat started just replacing parts and trying to get all the lube out of the Coolant, You need to do OA and see how Much coolant mixed in the crankcase lube, the Oil PIS is higher the coolant PSI, but it will mix when sitting for periods of time.
Woodster
Stop driving it!
There was no warning on my truck and I am now 8k out of pocket.
Tow it to a shop. This is a Major issue and I have been without the truck for 7 months on back ordered parts.
The dealership was WORTHLESS.
Woodster
Please see my reply
