P026D code
Tmckinney20
142
60
P026D
I never had this code until I installed a GDE tune. I have had it numerous times since and especially when towing. Spoke to the guy a few times at GDE, think it was Keith but I am not positive. Well they or he, keeps saying I have a vacuum leak. If it were a vacuum leak it would pop the CEL every time I drove it. I even put a smoke machine in the lines to confirm I did not have a leak. It is something to do with the tune and GDE does not know how to fix it so they just pass the blame. Typical no service after the sale company. If anyone fines any additional information or answers please post for all to see.
822
309
Very odd that you would have customer service issues with GDE. They are well known for their products and customer service. Following this thread and hopefully you get an easy resolution.
Tmckinney20
142
60
Brother I was surprised to. I like the tune and it's options. Other than the code, I like the improvements.
Gnurps
I got that same code on my 2020 EcoDiesel with GDE tune. Did a bunch of web searching and found confusing information, if you can call it that. Was getting ready to call Keith at GDE and then the code just went away, and its has not come back for months. I actually had two codes, P026D and P020B.
With the codes gone, should I consider the problem solved?
What is the CEL?
Tmckinney20
142
60
What is the CEL?
CEL is Check Engine Light. Yes, the light does go back off when a few more drive cycles have passed. But it is a never ending cycle of off and on with the same code. I would not call it resolved, but with the cel going back off the ECU does not detect any further problems until it comes back on.
hankinpageaz
I've had that same code too on my 2020 Ecodiesel. I installed a Pedal Commander when it happened. Since then I have removed the Pedal Commander, erased the code and the code hasn't come back yet. It's been a 1/2 year and about 25,000 miles ago.
I am assuming that the GDE tune has something to do with the acceleration of your truck. Also assuming that the code will keep coming back until the tune is removed or reprogram somehow.
