P04DB-00 Crankcase Ventilation Disconnected
kevin.tait
So, a little history on my 2016 ecodiesel. About a month ago, I got the service throttle control module code and limp mode, cleaned EGR diffuser pipe and MAP sensor and the code stayed off after resetting the code.
Now, I installed a CFT catch can today, went for a 100km drive and all was good. later in the day we went for groceries and the truck had a CEL come on. When we got home I read the codes. P04DB-00 Crankcase Ventilation system Disconnected.
I planned on ordering the stage 2 delete tomorrow.... Now I am thinking it is to late to save this engine. Any thoughts on this code?
67_Valiant
51
So that code indicates there is an out of range pressure differential between the crankcase and the reference(atmospheric pressure, I believe). If the sensor was unplugged or the vapor return hose was re-routed differently, that could trigger a code.
I had an engine with too much blow-by that triggered the code also (not a good thing). Hope you can figure it out.
1,002
350
A lot of horror stories of codes with catch cans. I wouldn’t worry too much
