Preemptive engine work
Mailman4105
Hi guys, just found this forum, so first time posting. Just wondering if there are any shops out there that are finding a way to key the timing gear and fuel pump gear to the cam? Just thinking of having some engine work done to ward off known issues. I have a 2015 Outdoorsman with 84k mikes. Full delete and GDE at 56k. I really love this truck and it does exactly what I need.
694
If the Shaft nut is TQ correctly its not necessary, DJ's in UT has the fix, Last I heard its required to bring the engine to them.
If your that concerned you can remove the CP4 and Check the TQ on gears CP4 and Cam/Drive Bolt/Nut.
