I have a 2014 Eco and 2 weeks ago it started blowing white smoke everywhere. Filled the highway, cab like it was on fire. Got shut down and fuel was everywhere. Had a fuel knock so figured injector stuck open an was dumping fuel. Finally today I was able to pull the egr cooler an parts off and removed the left valve cover. All internals are as should be so that’s a plus!!
Found a valve cover gasket broke and one bad injector. Also one part that I don’t know what the name is broken. The part the egr cooler mounts on that bolts to the side of the engine which the hoses bolt up to. The back stud mounting hole is busted off. I am looking for the name of it so I can check on getting another one.
Also, what all parts are needed and process to get rid of all this egr, regen junk.
Any help is appreciated.
