- Feb 15, 2019
- 915
- 333
- 2014
Well, at 179k miles, I believe my turbo vanes are sticking, or my actuator is bad. Haven’t dug too far into it yet, but it seems like the vanes are staying open, not allowing boost to build/ slow to spool up. I will keep everyone up to date with my findings as I plan to start with my map sensor, followed by disconnecting the actuator from the vanes, and trying to move the vanes manually to see if they are bound up, or if the actuator gears could be shot. I suspect it to be the vanes sticking because a few hundred miles ago, I blew apart an intercooler clamp, and looking back, I suspect it was the vanes not functioning properly, causing overboost. But I have zero codes, so I am basing my assumptions off of a random limp mode issue, with no codes. Hopefully I can help so done when I determine a cause! Also, I hope to replace turbo without intake removal, cab removal, or transmission removal if possible, but we shall see!!
