Transmission Fluid Change for the Ecodiesel ZF 8HP45
Russel
Hello Gang,
Are there any matched aftermarket transmission fluid for the 8 & 9 Mopar fluid ?
Thanks
286
Welcome yes there is do a search it is out there or someone will list it. Valvoline max life
cds13ca
217
79
A few links, one from ZF on how to do the oil change on the transmission:
Here are a few options of Compatible Oils:
Must be compatible with Shell M-L 12108
Amsoil
Valvoline Max Life
SofaKingTuned
72
25
We purchased 2 x gal of Hot Shot's Secret Blue Diamond Severe Duty Transmission Fluid and have about 1/2 gal left over.
Smoooooth, super super smoooooth shifts, lower temps etc. All the things promised.
Ronald Doupe
115
I will be using ZF fluid as the manufacture knows what to use, I have another brand car with the ZF 8speed have done that one already, why use something not approved ZF fluid is not that expensive
SofaKingTuned
72
25
That's a good question Ronald. If you look into the MDS, they are approved.
Better question is, what's ZF fluid?
If you look a the chemical breakdown it's ATF with dye in it that reacts to UV light in order to check for leaks.
