Transmission start off gear
duffy
Can the trans be told to start in 2nd gear instead of 1st gear. This helps in my auto starting in water or on snow.
4,366
1,158
That would require custom tuning I would imagine. I'm not totally sure anyone has had a need for that yet.
flying7
175
42
are you tryin to prevent slippage when taking off or??
1,281
353
With the amount of Turbo lag with the factory tune you need first gear even if it seems to be a short gear.
But if your concern is traction on snow and you're rocketing off and relying on traction control then your foot is the problem (and imo diesel characteristics likely aren't suitable for your driving style) not the transmissions gearing..
For the sake of simply answering the question yes. It could. But it would be custom tuned and it would lessen the life of your transmission because it will have to ride the torque converter to have the engine rpm high enough to reach boost and produce power. Same as riding a clutch. The gears are designed to have the torque converter lock by the time the engine reaches boost if not sooner and stay there.
I do understand that between that short gear and diesel's short rpm band it limits the trucks performance off the line. It's just the way it is. MPGs over 1/4 miles and 0-60
Brokedownbutgood
289
103
Ride the torque converter like riding a clutch really! They work completely different a torque converter is designed to slip. They lock up via hydraulic pressure when the tcm commands it too.
Now on to the real question, yes our trucks could be programmed to start in second. But that would require tuning the tcm which no one has done yet. Also you would still want it to start in first when your towing. So that would make it even more complex to program.
1,281
353
You must not be familiar with the integrity of a torque converter. Just as a clutch is designed to last so long with x amount of slip against the flywheel a torque converter that is ridden too much overheats the fluid, and after so long breaks down the material within the torque converter itself and when it fails dumps said material into the tranny doing severe damage.
Go take a 90s mopar and try towing in overdrive and let me know how long your transmission lasts because the torque converter won't lock. They were particularly problematic. But that goes for ANY tow vehicle. Overdrive isn't meant for that because if it's under load it won't allow the torque converter to lock which is no different from riding a clutch.
Now would you like to criticize my reference any more?
1,281
353
And second to this is transmission cooling which is driven by engine rpm not final drive which is why towing in overdrive even in a vehicle capable of locking the torque converter is not recommended because it requires higher engine rpm to increase fluid circulation. This is why even though you will get 1-2MPG less towing in 6-7th gear it's just what you do instead of lugging in 8th and sacrificing your transmission in favor of a MPG
Brokedownbutgood
289
103
Wow just wow. Towing in overdrive has nothing to due with the torque converter. It has to due with the power band of the engine and constantly down shifting which creates excessive heat. Also overdrive clutches are smaller in diameter and are deisgned to take less torque.
Just a side note I used to work in a transmission shop, but what would I know.
diesel power 2014
27
Tur
diesel power 2014
27
Turbo lag really better have your turbo and exhaust checked.This engine with complete "green" running technology
has one of the best spool up time for a turbo in any pickup truck.
