Vibration
Ecoram2017
Hey guys I’m new to the ecodiesel forum.
I have a 2017 ecodiesel big horn.
I was running original tires and mags with 2.5” leveling kit.
I changed the tires to a 33” more agressive and LT TIRE. There was a slight vibrate going on and then it got worse with time. I thought maybe I bent a rim or something which I New I didn’t so I went out and bought some new mags from HD. In the mean time the dealer found some problems with my diff rebuilt it and balanced the drive shaft. I put on my new mags with my new tires and the vibration is still there. Also when I put a maxi trailer on it makes the vibration worse. Do you guys have any idea what can be causing this vibration. Now the dealer is giving me a hard time and is saying it’s the tires but when I got them balanced it didn’t take a lot of weights or look off to me.
Give me your opinions
522
135
I would try Road Force Balancing the tires before spending any more money. The dealer should have a Road Force Balance machine, and some tire shops do. You can call around and see who will do it and how much. Some dealers are 30 dollars a wheel and some are 10.
Fair warning - even good Michelins fail road force balancing and they have to send you new ones. I would say 25% of all tires fail.
Ecoram2017
See idk if it actually is my tires the problem. They rebuilt the diff because there was bearing problems etc I feel like it would be something in the diff.
522
135
You said: "Now the dealer is giving me a hard time and is saying it’s the tires but when I got them balanced it didn’t take a lot of weights or look off to me." - So I gave you my opinion which is a way to rule out the wheels and tires. If these wheels and tires Road Force balance show him the report.
JMF157
17
It is a long shot but do you take the same road, same lane and at almost the same speed every time you encounter the vibration? I ask because here on Long Island, NY we have a few roads that are build to NY's very high standards of CRAPPY or worse. There is a stretch of Sunrise Highway that makes both this 2016 EcoDiesel and my last 2005 Colorado bounce and when my trailer is attached the bouncing is so bad it is almost like a vibration message. It turns out the when the roadway was poured (concrete) it was never leveled properly and has a patterned ripple in the surface. You can see it very clearly at night when the headlight cast shadows across the peaks of each ripple.
Ecoram2017
Ecoram2017
Yeah at first I was thinking it was that because down here in Quebec the roads are crap , but it wasn’t the vibration is caused on any road over the speed of 100km/h 60miles about and more. They changed the diff gears and bearings once and balanced the drive shaft. Seems to me there’s something not right
717
Its the tires....Balance Masters May solve the problem.... I have a Vib in My 2013 3500, I spent $1000s on chasing , Centramatic's, Balance Masters, 10 different balancing's, 3 sets of different tires, DL replacement ugh.
