what is are options on what brand of oil we can use
John Gardner
I just purchased a 2014 ecodiesel I love the truck. Just wanting some advise on what oil to use as far as brand and weight thanks
387
the oil spec recently changed. from the diesel supplement.
We recommend you use 5W-40 synthetic engine oil such
as MOPAR or Shell Rotella that meets FCA Material
Standard MS-10902 and the API CJ-4 or ACEA E9/E7 or
ACEA A3/B4 engine oil category is required.
4,368
1,158
Welcome to the site!
The other @John is right.. sourcing oil is a little cheaper now and easier to find. Stick around and ask any questions you may have.
John Gardner
That's good news when I got the truck I heard you could only use penzoil and Mobile. Makes it a lot more cost affective being able to use Rottela thanks
cevans
141
90
CJ-4 5w40 synthetic opened up a huge range of options:
Shell Rotella T6
Mobil 1 Turbo Diesel Truck (aka Delvac 1)
Chevron Delo LE
Kendall SHP
Plus a LOT of others. I'm waiting for clarification about ACEA A3/B4 approval, which is mentioned at one point in the new documentation. If A3/B4 is also opened up, FCA is basically saying that any high quality synthetic 5w40 low-ash oil will do, which is even better news.
Hawkeye
Clarification-
M1 TDT is NOT the same as Mobil Delvac 1.
M1 TDT does NOT have MS-10902/Cummins CES 20081, so it is not an oil that meets all of the specs.
Delvac 1 ESP 5W40 has Cummins CES 20081 along with just about every other builder approval.
