2015 w/a reductant pump 2 control circuit high dtc
384
When you get the code, see if it matches any codes indicated on this TSB.
  • TSB 18-018-16.pdf
pro439
No this particular code is not in this tsb. So there may not be a software update for it and there is an actual problem. I haven't found anything on a dodge but ford has a similar code just don't know if it's the same pump or wiring
384
Are you sure it's not P208D-00?
If so, I believe it's related to the DEF Pump.
pro439
Yes I saw that Ford has a similar code.But don't know if the wiring or the ts is the same.I got a wiring diagram but don't see where there's 12 v's for a short to occur
pro439
P20FD-00 The letters aren't found really anywhere except on my snap-on scanner
