2016 Ram
345
162
43
85
San Diego County
www.johnfjensen.com
968
381
63
OHIO
HD Diesel in Canada would be my recommendation. I don't have experience with SFT.
345
162
43
85
San Diego County
www.johnfjensen.com
I
I do have considerable experience with SFT.
SFT has great tunes, is customer satisfaction oriented and the lowest prices (goes on sale often) and is in the great USA.
I have used the GDE tune (same as HD Diesel's ??) and find the SFT tune to be as good if not better at mpg, towing and low-end torque. The negative, to some, is their regen cycle is more frequent than GDE's. However, I've read that GDE's longer intervals come at the cost of higher temps, maybe too high. The SFT transmission tune is likewise excellent. SFT has a lot of very satisfied customers.
I'm not badmouthing HD Diesel's or GDE's tunes as they are great tunes. I'm just offering my experiences and knowledge with SFT.
968
381
63
OHIO
The high regen cycle is a killer in my opinion. Every 200 miles?!? That's absurd. I wouldn't go with a current GDE tune or SFT. The original GDE tune stretched out the intervals and was great. HD Diesel does this as well.
345
162
43
85
San Diego County
www.johnfjensen.com
Not sure where you got 200 miles. I track my regens. With SFT tunes locally I'm getting about the same or slightly better intervals as a stock tune. My GDE tune was about the same for local driving. On highway traveling it's a different story, 100% Freeway & hiway I get between 767 mi & 1003 mi which is about the same as I did with the GDE tune. Caution - This data is pre-AEM SFT tunes. I have no data since my recent AEM flash and SFT's corresponding tune.
I don't believe frequent regens are a "killer" as they are merely cleaning the DPF when necessary, which is good. They are however a real pain, they are happening because of local driving and the regen fires off when you are local driving - very inconvenient. The real question is why are they frequent? That's a whole 'nother topic for which there are many answers and as many disagreements.
I do know that my manifold easily passed the soot test when the AEM was flashed. IMO that is because I have been tuned since early on. First with GDE and then with SFT since the CARB denied GDE in Califunny.
I'm no expert, not saying I'm right and I'm not soliciting, just passing on my experiences and what I've read.
968
381
63
OHIO
I'm saying the 70-200 mile range between regeneration is for the current GDE tune available in the US. That's about the same as factory programming. I frequently ran 700 miles between cycles on the old GDE tune and loved it. I thought maybe you were saying SFT was less than today's legal tune. That would be too frequent!
But a quick perusal of the classified section by the OP might just reveal a PRE-EPA GDE tune for sale, possibly even located nearby.
Reactions: John Jensen
TMayor
ohio
How many miles does an average Eco Last? If I do delete and modify the exhaust the truck has no resale value as I see it.
Am I thinking about this correctly?
968
381
63
OHIO
No way you'll get an accurate number to that longevity question.
You're right, the unmolested used diesel has a higher resale value for sure. I justified the delete for myself as preventative maintenance for the second 100k miles, if not more. But if you plan to only have the truck a short time, an emission intact tune would be your best bet.
Reactions: BoostN
TMayor
ohio
You still have your Eco. If so what all have you done to it. Mine is showing the PO299 Low turbo boost long wit Po402 EGR Flow Excessive.
I like the truck But I need a dependable truck. Would an Emission tune help to make these code go away? On a separate note, I thought I saw somewhere you are in Ohio.
Ronald Doupe
90
20
I
X2 to what John said in all respects
968
381
63
OHIO
I tuned out the EGR via GDE from about 40k miles. Drove up to their shop on the way to the Detroit Auto Show. Recently was getting EGR related codes so I removed it and went full delete with a tune from HD Diesel in Canada. My truck is at 100k miles and I fully expect it to run another 100k without major problems. And my summer mpgs hover around 28 riding on stock Rebel wheels and tires and 3.55 gears so I can't complain.
I don't know much about the PO299 code, maybe TC Diesel will chime in. I do know first hand an emissions intact tune is still susceptible to EGR codes, but a delete tune would eliminate those all together.
The way I see it, an EcoDiesel owner (in Ohio) has two options, keep it all stock and depend on the dealer for EVERY little thing that goes wrong and hope they are competent and fair; or take control, tune out or delete problematic emission systems and roll the dice that you don't spin a bearing. No tune is going to stop that. Neither are great options, but I like having control so I chose the latter and have been rewarded with no drama, just routine stuff along the way. It's been a good truck so far.
I am in Ross County. If you're in the area look me up.
