ABS Light with Remote Start, Cruise doesn't work
Joe vela
Has anyone had trouble with ABS an engine lights coming on and when it does remote start, cruise won't work we have made 2 trips to the dealer
4,372
1,158
I've not seen any mention of that Joe.
Welcome to the site, hopefully someone can chime in that has any info. Let us know how you dealer visit goes!
1,284
355
I have no idea what is causing the ABS malfunction but that light being on is what is prevention cruise control.
Air suspension, ABS, esc, so on and so forth; anything regarding the suspension o braking system that puts on a EVIC message and your cruise control will not operate.
I had a little trouble with my air suspension (playing with it too much) and had a similar issue with cruise.
1,284
355
I guess get the dealer to check out the ABS sensors and wheel speed sensors. Something happened
Joe vela
Well got my truck bk they said it was the speed sensor but his expression showed like he was not sure
1,284
355
Theoretically that should be it. Maybe damage to the wiring for it was allowing moisture to throw it off
Mharrison
373
105
Have you taken a look at BoostN post of the latest recall for the rear axle it states contact your dealer immediately if your abs light comes on.
1,284
355
I don't know about that being a complete failure. I'd think if ABS light came on it'd be wayyy too late. And he seemed to have a reoccurring issue whenever moisture was present. But we haven't gotten an update so who knows..?
Mharrison
373
105
I figured it may be worth mentioning. It's not very often we see moisture related electrical issues anymore with all of the weatherpac connectors etc. Not saying it's not possible but with our conditions might have been more coincidence than cause.
1,284
355
That's why I referenced a possible damaged wiring section or similar in the beginning. I understand there's a lot more preventative measures towards water resistance on wiring but there's still things that could happen; i.e. over torquing the wheel sensor or misaligned sensor during the installation cracking the housing, or damaged wiring.
1,284
355
But you're right in that situation a dealer should be more than sure especially during R&I when they find damage so who knows really without the physical hands on and in your face diagnosis
Mharrison
373
105
There is no doubt....the modern wire insulation is garbage we have replaced several harness on our tractors due the the loom wearing right through the wires. Speed sensors anymore though are typically on the transmission.
1,284
355
He means the wheel speed sensor for ABS/ESC/TC not referencing it as the actual speedometer sensor
