Ecodiesel. 130500
dargarza
Checked the codes, po386 , crankshaft position sensor. Now I want to clear the codes, I'm sitting in lymph mode, need to start it, so I can get it over to the electric auto tech shop. Called the shop they gave me an idea. Any back ups?
721
That takes fixing and, in Many Cases, WITECH to remove the code and de-rated Power. Your posting is confusing, ETC and CK sensor two different problems?
dargarza
I think ETC is false message, throttle pickup when driving is normal even at idle I can drive without throttle interference. Truck is hard to start, already taken out of lymph mode and it will start. The PO 336 for crankshaft sensor is what. I'm concerned about.
721
ETC, cannot be false, unless it's just Lock in the EVIC, Thats were it will require WITECH, There May be a way with Alfa, hopefully someone will chime in on How they were successful with ALFA. Still Need more info, do you have the latest flash for the CSK from Ram?
