Ecodiesel Oil Brand and Filter
ToeTruck
All, I am curious as to the type oil and filter most are running in their eco. I use Rotella 5/40 and use the Wix filter. I think the manual stated Rotella or similar.
I also know oil discussions can get long based on personal preferences, so I'm not looking for specifics, just if there may be a better option I could use to increase the life of my eco. Research seems to point to Delo, Rotella, and Amsoil. Any insight is appreciated, Thanks for your time.
4,328
1,143
Lots of good info here:
As always, everyone always has their favorite oil brand. :D
Ironcity
41
Being that there is a high failure rate for the ecodiesel engines, I only use the mopar oil filter and only use the rotella t6 5/40 since Ram specifically mentioned that oil after they changed the weight of oil to be used in this engine. If you are still under warranty that is. I know that they are supposed to honor warranty with equivalent brands, but I don’t chance it. My eco died last year and I had zero warranty issues. A brand new engine was put in with no charge or hassle. If you are out of warranty, I would try to save some money on an equivalent filter.
scoffman
30
20
I run the white lady with Shell Rotella T6 and the K&N oil filter.
Rints79
I run Rotella T6 and a wix filter in my '18 eco.. a lot of failures with the ecodiesel come from a quick start after an oil change. One of my buddies is a mechanic at a Dodge dealership and he warned me to not start it up for 20-30 minutes after I've added the oil because this engine has a slow coat
CAVEMANN
388
130
I use Rotella T6, & a bit of HOTSHOTS FR3, & once in a while some stiction eliminator, I order my filters from IDPARTS.COM, they have a filter that they claim it the EXACT same filter as the MOPAR filter & it looks identical. IDPARTS also sell service paks that includes filters and different oil options, they also offer filter options in the paks. I would stick with the OEM fuel filter as some have said the aftermarket filters can swell if you have water in the fuel.
