Electronic Throttle Control Failure Light
rondukester
I have cleaned the PAM sensor and EGR tube. The senor was clogged with suet. The tube wasn't to bad. 80,00 miles on 2014 Ram 1500 3.0 Eco Diesel. Installed a new intake filter. Plan on cleaning the MFM sensor this morning. ( with MFM cleaner) Have tried to reset the light by disconnecting the negative battery cable for 3 hrs. no luck. As I have no engine diagnostic equipment. Any help would to appreciated. Thanks!
4,290
1,127
You can always try the auto parts store, they have a scanner for free that maybe will clear the codes. Depending on which scanner...
rondukester
Cleaned the MFM sensor. Had the code reset all is good. Thanks for the help!
