- Oct 18, 2015
- 1,227
- 325
- 2015
So this morning going to work (only a mile across town) I get the lovely comment from my wife as I'm climbing out of bed at 6:30; "oh yeah the truck is at 90%" (dpf)
It's -15°F and the truck isn't even running yet. And I have to be on the clock in 25min and I have 3 dogs to get outside.
Anyways I get out of the house in a matter of minutes and have about 12 minutes to get the exhaust up to temp and run a regen; really pushing it. Knowing I cannot just drive to Work and run a high idle regen in the parking lot which I normally would, because it takes too long I proceed to drive across town using only 1st and 2nd gear. Using the driving load to push higher egts and regen quicker in the cold.
Well it works, it starts a regen within 6 blocks or so. So I proceed to continue lurking through town and doing 10MPH rolling stops to keep my rpms above 1800 in 1st gear. And make my way to the new development subdivision near work where I have about a quarter mile loop with gentle turns and only one stop sign. And Virtually no 6am traffic. Anyways as I'm getting there it finally drops to 80% well it's working. Proceed to run about 3-4 laps around this subdivision in first gear between 2k-3k rpms and am able to get the regen dropping almost 20% per lap. Pushing 8 minutes to be on the clock and it finally completes which is actually only reaching less than the 20%. So I proceed to work using the same method of rpms and gear usage but higher speeds to hurry up and get to work.
Then to use the slow cruise through the parking lot to cool down the exhaust. Which I know I didn't do thoroughly enough and I could have used the remote start and let it idle down and even use the uConnect app to shut it down from in the building but I let it be. It's still -15° anyways so ambient temps will cool the exhaust Turbo and engine bay pretty quickly so I just let it go.
Anyways overall I drove about 3.5 miles and had a complete regen from 90% done in a matter of 10-12 minutes. Cutting it close but I had a pretty effective "emergency" regen in short order without running into 2 more commutes before being able to complete it otherwise and I'd be damned if I plugged that filter and ended up with the truck going to the dealership to run a forced regen.
Anyways not very happy times between the wife and I this morning but I figured out how to handle an otherwise pretty bad situation in short order.
