Engine failure after computer reflash.
Terry Upchurch
Three and half weeks after computer reflash I had engine failure on my 2015 1500 Ram ecodiesel. My truck is still in the shop having engine replacement. Just wondering if anyone else encountered this problem?
MSP548
202
62
It is truly unbelievable to me that FCA rolled this engine out to market. Clearly it was a mistake that is costing them millions.
My heart aches every time I read a new post by a new member such as this one. Unfortunately, these posts are far too common.
cds13ca
216
76
so sorry to hear that. Are they covering it under warranty?? What caused the failure, did they say?
Terry Upchurch
It is not covered by warranty due to mileage. It has 121000 miles on it. No word on cause of failure at this time.
cds13ca
216
76
wow, I hate to ask what this is gonna cost... that's brutal. :cry:
1,051
424
How is it NOT covered? With the AEM comes cash and extended warranty from date of reflash, no matter the current mileage, that's the whole incentive to taking the truck in....
876
431
The AEM extended warranty is very specific on what it covers. It does not re-warranty the engine.
Consent Decree Appendix E
Extended Emission Warranty
Subject to standard limitations that must be identified to Eligible Owners and Eligible
Lessees, which may set forth exclusions like accident, abuse, neglect, or installation of noncertified parts, and applicable existing warranty provisions that will remain in effect, the
below.
• Catalysts
o DEF Injector
o DEF Injector Controller
o DEF Storage Tank
o DEF Delivery Lines
Cherokee only)
• Parts of the Fuel System
o Fuel Injectors
o Fuel Rail
o High Pressure Fuel Line
o EGR Cooler Tubes
o EGR Cooler
o EGR Valve
o EGR Temperature Sensor
o EGR Cooler bypass actuator
o Oxygen Sensors
o NOx Sensors
o Fuel/Water Separator Sensor
o Particulate Matter Sensor
o Mass Airflow Sensor
o Boost Pressure Sensor
o Crankcase Pressure Sensor
APPENDIX E TO CONSENT DECREE
MDL No. 2777 EMC
Case 3:17-md-02777-EMC Document 484-1 Filed 01/10/19 Page 207 of 224
o Throttle Valve
o Exhaust Temperature Sensor
• Throttle Valve
• Cylinder Head Assembly, Including Valves, Springs, Valve Spring Keepers, Valve Seats,
Cam Bearing Caps, and Manifold Studs (Camshaft and other components of the assembly
are not covered)
Additionally, the Extended Warranty shall cover the cost of any OBD Diagnostic Scan
for malfunctions that trigger the OBD Malfunction Indicator Light (MIL), regardless of whether
the malfunction is attributable to a part that is covered under the Extended Warranty
1,051
424
Looks like the engine is pretty much covered by the above posted document. What am I missing? Crankshaft bearings?
solstar
I got the VO8 recall Upgrade on 07 May 2019. Since then it has been in the shop 5 times for a total of 110 and counting days (it is currently in shop). I have sent a "buyback packet" to the recall lawyers under the terms of the Consent Decree, (what all parties legally agreed to do) Paragraph 45 section d (lines 113-116). It basically says that if vehicle has been in for warranty covered repairs for a "cumulative thirty days" (with a few exceptions) that FCA has to buy the vehicle back under the 'Lemon law' under "NADA Clean Retail" formulation.
solstar
There are TWO extended warranty conditions, from the date you get the VO8 Approved Emissions Modification. 1- ten years, 120,000 miles. 2- four years, 48,000 miles. Which ever is greater. They both are running at the same time. If your truck has 120,000 miles on it then the "four years, 48,000 miles covers you. The START date is when you have the AEM recall flash done.
