"Engine Will Not Restart in 200 mi Service DEF See Dealer"
a2charters
Friends. Looking for some help.
18' Ram Eco, 76 k miles.
Got this message "Engine Will Not Restart in 200 mi Service DEF See Dealer"
Please help with possible solutions??
Thanks
694
The DEF Injector is likely caked up shut, You have 2018 WITH SGM, you will need the bypass Cable or module ,Plus ALFAOBD and The MX or WITECH to clear the message.
a2charters
Thanks. I cleaned the DEF injector but the message remains.
Help me understand this? Rookie here. Again, thanks.
"you will need the bypass Cable or module ,Plus ALFAOBD and The MX or WITECH to clear the message"
694
2018 Plus have Secure Gateway Module, Some Codes can be deleted without the Cable/Module, But I don't think you can Touch The Body module without the Cable/module that bypasses the Gateway Module, and to top that that message is a protected one , So It takes ALFA ,WITECH or equivalent to delete Remove it.
Thai guy does OK at explaining the Procedure
2018+ FCA Security Gateway Module Bypass - Infotainment.com
