Fuel transfer tank
Althecraneguy
Can't have a work truck without a transfer tank. 51 gallon rds tank with 15 gpm pump. I'm not familiar with how bed covers are mounted. Do y'all with bed covers think I have room for one or is the tank too tall?198219831984
146
19
that is the same tank I have in my bed with a tonal cover over it works great
Althecraneguy
Thanks for the info. I'll post a follow up when I put one on. Got a few things that I'm gonna do first.
164
43
Blaine
www.tcdiesel.com
Until you get a cover on that bed , correct that nozzle ,Facing upwards C'mon.
If theirs enough room use this filter when you change it out AE-3AZL. I change Mine Once every 24 months .. the only exception to this is when it the filter shuts down the Pump Flow, it will eventually curtail the flow 100%... Thus you never need to worry. Using the Zinga will allow you to run Your factory Filter to 50K miles or 2 Years...I change My 2003 5.9 Factory filter 3 times in 141K miles and 12 Years.
164
43
Blaine
www.tcdiesel.com
If you going to leave in the Bed and NOT elevated Install 1-way valve. You would not want the Fire Dept and your local environmental agency sending you the bill for the clean up... in the unlikely even the nozzle leaked.
