guage information
arnie
I was going down the highway with light traffic at 70 mph and decided to look at the gauge cluster readings in the dash .It was 88 degrees out . Coolant was at 206 , trans temp at 181 , oil temp at 219 , oil pressure at 40 psi . All at 2000 rpms . No load . Do these numbers look average compared to others out there ?
2016 1500 Ecodiesel crew cab 4x4 6.4 bed .
Scottd
78
25
Almost exactly what mine shows all the time when not towing.
arnie
Ok ,thanks Scottd. was a little concerned with the transmission temp . My 96 Cummins 2500 transmission doesn't even move off the needle running MT but then the sensor is in the pan . The Cummins sure runs a lot higher oil pressure also .
Scottd
78
25
Arnie, our oil pressure is not a true real time reading. It’s some calculation between oil temp, rpm, and who knows what else.
FrankieZ
Actually your readings are less than mine on average. I tow a lot, but even when not towing my readings are typically, coolant around 210, trans 194 and oil 216 and this is on a 65 degree day, driving only 20 miles. I think these are way too high! Anyone out there know what is normal? Feel like it should go back to dealer
