Hi to all years owner of 2018 ecodiesel
TerraMcDuff
I have the same year as well, and we have been having problems. Can’t find this code in the list.
BTdriver
128
51
I believe "reductant" is the DEF fluid and your pump isn't functioning properly. Check your DEF spray nozzle, it could be clogged with urea deposits, causing the issue.
When I had issues with my DEF system (don't recall the code), I cleaned the nozzle and mount hole with steam*, cleared the code and problem solved. Lately I've been using a 50/50ish mix of the DEF with anti-deposit additive and regular (read: less expensive) DEF without problems.
*Comforday Handheld Pressurized Steam Cleaner​
