High idle?
Waggie
17
So I spent most of last night reading the owner manual for the Ecodiesel. I wasn't able to find anything in there about an elevated/high idle setting for these engines. I was just wondering if there is such a feature? I know on all of my Duramaxes, there was a setting for elevated idle in the DIC, or a high idle setting with the parking brake set.
Thanks in advance for any responses!
BunkerOil
There is no manual way of doing it. It is fully temperature related I think its 1100rpm @ 0C and 1400rpm @ -10C
381
GDE has a high idle option. It's based on ambient temps, no user control.
1,226
325
That's not GDE that's ram factory. It idles higher when the fluid is cold.
There is a high idle switch available after market. It's compatible for the ecodiesel but designed for the Cummins. Regardless it's just plug and play on the rams fly by wire. But it runs almost 200$ but has many high idle speeds. I'd be using mine for stand still forced regens whenever necessary. Will be put in over the summer for next winter.
1,050
422
GDE does have a high idle option in their new tune.
vandan
53
14
Gde tune ramps it up to 1500 rpm after it is started for about a minute to let the oil get thinner and it sounds more like a diesel
cds13ca
216
76
No such feature from the factory on the eco
That's not true, if you put the heater on FRONT WINDSHEILD DEFROST with the car temp set to high heat, when you start the truck, stock will run a higher idle in the cold (usually around 1300 rpm). It's not comparable to the GDE high idle, but it does exist.
