Oil change
R4L
14
I’ve read a lot of complaints about cost of oil changes at the shop. Not necessarily on this forum but others. I’m new to the ED but have always done the oil changes in my Hemi. Question: Is there something that makes it harder on the ED? What oil and filter do you run? Planning on doing my first oil change this week. 2017 Laramie 4x4. Thanks
4,288
1,127
Not harder, shops love to take advantage of a diesel, and up charge for it. Everything you need to know about oil changes:
Ironcity
40
Easiest vehicle I’ve ever had to change oil. I use Rotella T6 5/40. I use the Mopar oil filter. Make sure you get the updated one. I also put on a fumoto quick valve instead of the drain plug. No need to jack up the truck. Slide under and open the valve. So easy.
840
416
Like Ironcity said, the Eco is the easiest oil change of any vehicle I have owned, and I've owned several in my 86 years. There's a couple of things important, such as let it drain for a while as oil flow through the Eco is very slow.
Mopar # 68229402AA filter or a quality equivalent
10.5 quarts Shell Rotella T-6, Full Synthetic, 5w-40 or a quality equivalent
FCA changed to Shell Rotella T-6, 5w-40 (5th Edition Diesel Supplement, 7/2016)
Replace drain plug with a Fumato F106N Drain Valve - 14mm-1.5
Drain oil for 20 minutes to be sure all is drained.
Install Fumato valve and filter.
Replace oil, wait 20 minutes, then start the motor for 1 minute and shut off.
Wait another 10 min then check the oil for proper fill level.
EVIC Oil Life Reset.
On confirm screen, scroll up or down to get “OK” screen. Do not push “Confirm”.
Scroll up or down to get “OK” on the center window. Then push to confirm.
Easy Peasy
Ironcity
40
Easy Peasy
And one thing I would add is to make sure the engine is at least warm. The oil drains much faster since it does drain so slow.
tlbaldwin
I went to my dealership and got a quote on what it would be for an oil change. They wanted to charge me over $300!! I told them no. Went to a local shop that I am familiar with and I pay under $100 for oil change and tire rotation. The dealership told me it was an upcharge because the oil filter was bigger....yeah not entirely accurate. May be but not by over $200. Call around to see if there are any shops that are familiar with EDs.
scoffman
30
20
Hey
Easy Peasy
John,
would the Fumoto F106SX valve work for our trucks? it appears to be an updated version of the F106N, and has a rotating 90 degree angle valve. That way you can set it to point down.
840
416
Hey
John,
I am not familiar with it, all my valves drop straight down. F106 is the right number for our thread size, so it should work. Not sure if I would buy one as the rotating feature could be a leaker, but Fumato has a great reputation for quality so it shouldn't be a problem.
I can see the demand for it as so many think they'll breakoff the strait down model, especially off-roading.. I have never heard of that happening.
scoffman
30
20
Yeah I started researching the F106SX valve and there are some people who say it leaks, but the biggest complaint was the small nipple size and the hose popping off. I forgot that our drain plug is straight down. I don't do any off-roading so I think I'll go with the F106N. I'd like to put a small hose on the valve when draining so when it gets to the slow steady stream the wind won't blow the stream around.
