Problem since code fix..
Wshaneb
27
Had dealer required code fix over 6 weeks ago (2015 ram ecodeisel) and system has not regenerated yet????!! I don't put many miles on truck but it used to regenerate at least every 8 days or so. Anyone else having problems since code fix?
4,291
1,127
Welcome! how do you know it's not doing a regen? Are you tracking it with a monitor of some sort? If the truck is working properly, it's designed to be non intrusive to the driver so you know it's not in regen mode.
Wshaneb
27
It is not using and def fluid..
JohnnyMac
75
23
Did you buy it new? I'm guessing it had a GDE tune on it and since the dealer performed the AEM flash (and overwrote the tune) you no longer have the "regen in progress" report. My 2018 and I believe most all stock EcoD's do not report when the truck is regenerating, it all happens in the background.
Wshaneb
27
It is not using any DEF. fluid.....
1,051
424
8 gallons will last +/-10,000 miles. It's hard to tell if any is used over a short stretch of time. Why do you say it's not using DEF?
Please note. DEF fluid is not used for DPF regeneration. As a matter of fact the DEF system is disabled during a regen.
