Sofa King Tuned
SofaKingTuned
72
25
Hello there EcoDiesel owners!
I'm new to this website but not new to the EcoDiesel. I have used a lot of information from this website and have been very active on the FB groups.
I did come up with an awesome transmission tune with a great value. I'm not trying to advertise here, I'll post it in another spot. Stay "tuned"
I personally have a 2015 Ram EcoDiesel Outdoorsman 4x4 with GDE's supertune and SFT's transmission tune.
Chaindawgg
Why did you choose GDE for the Engine Tune?
SofaKingTuned
72
25
John speaks the truth below! I went with gde originally for the engine tune, I could not justify the transmission tune as there were no reviews out there that gave any sort of description except for, it's great, or wow. Was not convinced to drop $600 for that. And that's what drove me to originally developed the SFT transmission tune.
Fast forward a few months, in February I released the OBD2 flash ability for the engine. obviously people were waiting a long time for this and here I am coming from nowhere all of a sudden tuning the EcoDiesel engine via OBD2 yet these other companies could not for so long. After purchasing the gde super tune and being very disappointed that drove me to develop my own for the EcoDiesel, stage 1 with all the emissions intact, and Stage 2 fully deleted off road.
With the gde hot tune, speaking from personal experience I really have a neutral response but positive when it comes to MPG. I was happy with the EGR being shut off and the increase of MPG. Being able to set the cruise control At a lower speed and all that was great as well. I was very disappointed with the super tune, I had to barely press the throttle otherwise it was going to smoke like a chimney. Absolutely no noticeable increase in horsepower but it did make my engine sound like it was pre- detonating when it was not supposed to.
Working the clock basically 24/7 for weeks, I partnered with an engineering company to develop to Stage 1 and Stage 2 engine tunes. There's hardly any smoke with the fully deleted tune. There's absolutely no throttle lag after 800 RPMs. The only throttle lag experience is from the actual turbo having school up. Stock there's a 2.8 second delay programmed in there from the factory. We keep all the safety measures in place, the highest torque output is 712 NM, this is safe for the transmission, others are well over 800 NM. And that is fine for them, they will even advise against using the other tunes. We highly recommend hours because we want to keep things safe, within check and increase the longevity of your engine and transmission.
I did not get any money back from gde, I could barely get them to respond to an email after asking for the super tune and if I did things correctly. at this point, the company itself and disappointed in the ownership as for the quality of their tunes, I would recommend the gde hot tune to somebody with minor mechanical know how to remove the airbox and install the ECU.
I will say for Father's day Sofa King tuned LLC is giving 20% off to everything in the store. That means you can get an engine and transmission tune shipped priority 2 - 3 day shipping for only $720! All tunes are OBD2. You just need your Windows computer and the vehicle. Turn the key on and off when instructed and that's about it. Get phenomenal increases in MPG, drivability, longevity. Enjoy your new vehicle for a long time and less time spent at the pump fueling up
Chaindawgg
Great information!
So once someone purchases the tune, they will have access to reinstall the factory if needed? Basically, the software is always available for stock, stage 1 and stage 2?
On the offroad tune, do you need to alter the exhaust system or run through the current exhaust system, but turns off EGR?
I appreciate the details.
SofaKingTuned
72
25
Great information!
You got it! Flash whenever you want. Offroad requires offroad exhaust. 0 exceptions.
For the EGR, yes that too.
Luc_sko
27
Stage 1 also eliminates the EGR also correct?
I have read lots of good reviews for your tuning. That special your running is hard to pass up.
SofaKingTuned
72
25
It can, please check sofakingtuned.com/FAQ for more info:
Q: DOES THE SFT TUNE DISABLE THE EGR?
With the SFT Stage 2, YES! SFT Stage 2 tune is exclusively off-road use. This will delete your stock exhaust. With either SFT stage 1 or 2 ECU tune, if you select "yes" to "EGR removed?" During checkout, your tune will reflect accordingly
Chaindawgg
To confirm, do you need to do an offroad exhaust if you remove EGR? Obviously a rookie here.
SofaKingTuned
72
25
No worries, we all start somewhere. Hopefully this information helps:
EGR and your exhaust are two different systems that tie together via the EGR tube off the exhaust manifold.
The EGR is not inline with the exhaust. It simply taps into the exhaust so it can flow exhaust into your intake manifold effectively filling your engine cylinders with soot, killing it. How nice. Right?
Exhaust has the DPF, diesel particulate filter, responsible for burning off this soot during a regeneration by injecting excess fuel into your cylinder is causing the palladium material inside the DPF to heat up (burns soot)
The SCR, selective catalytic reduction is also a plate like structure that gets d e f, diesel exhaust fluid, a urea compound mixture sprayed onto the plate in order to lower nox emission levels.
Remove EGR = need EGR delete kit
EGR turned off (software) = can use block off plates
Stage 2 off-road only tune = you MUST run aftermarket race only exhaust (will not have DPF/SCR (def)
Chaindawgg
Okay, Thank you very much. I think I will just turn the EGR off via tune to keep it all stock otherwise.
stevei
26
24
Is your tune Calif. compliant? How hard is the installation, I'm not very computer savy? Is it not a problem to go back and forth between new update and your performance tune? Thanks for your time.
SofaKingTuned
72
25
Yessir! We tune in Cali since ALL your emissions will be in working order and they're still functional.
Yes you can swap back and forth.
Please review "how does it work" on sofakingtuned.com/faq
stevei
26
24
Just purchased your program, I tried to log back into my new sofaking account my computer said this was a fraudulent site and should close immediately. Tried to call your number 702-sofa-king number cannot be completed as dialed to many numbers. I canceled transaction and my credit card. What's going on?? Let me know?
SofaKingTuned
72
25
Sir, I'm not sure what you're referencing. The www.sofakingtuned.com website is perfectly safe. With SSL connections. Plus the payment is ONLY through PayPal right now. 100% safe with their automatic $300,000 purchase protection.
SofaKingTuned
72
25
Gde they are there to help their customers. u get what u pay for
Can you reach them via email? After hours? Weekends? Holidays? Nope. You're right, you're over paying for an under performing product. Not our cup of tea!
Green Diesel
115
105
Green Diesel Engineering replies to customer needs during business hours, after hours and on weekends. We can teamviewer in if needed as well. Customer service is important to GDE and we strive to have 100% satisfaction. Give us a call. 248-977-9531 or email at [email protected]
