Sparkplugs and miscellaneous upgrades
MikeSwanson
Just had a new intake manifold installed as well as a GDE hot tune and transmission tune(highly recommend)
Having some problems concerning my circuitry looking to get new fuses and spark plugs
Could someone give me the exact brand and specifications for spark plugs and fuses and if there is anything else that will pro long the life of my truck
I'm all ears
Thanks
1,051
424
Well Mike, not so sure you should even be messing with a fuse if you're looking for spark plugs on your Ecodiesel truck.
MikeSwanson
My apologies gentlemen meant to say glowplug
on another thread for my atv where i m looking for a new sparkplug
MikeSwanson
Moving forward,(that was one of the dumber things i ve said in quite sometime)
Is there anything anyone would recommend just to pro long the life of my truck?
GDE tune works great will be having my circuitry looked at would like to get new fuses not sure if it necessary or not aswell as a new glowplug
Just put in new air filter and fuel filter
Just curious if theres anything else i should be doing around 185,00 km
726
Glow plugs on the 3.0VM are generally corroded and unable to remove. This picture is someone who attempted to remove them and they broke off and the tips dropped and took out the engine.
1,051
424
Are you having issues with the truck? I wouldn't mess with the glow plugs or fuses unless something doesn't work. Maybe have some spares on hand. At your mileage fluid changes and wearable items like tires, suspension, and wipers are things to check. You can inspect belts, hoses, and clamps under the hood as well. Grease anything you can and clean the undercarriage. But don't go fixing what ain't broke. Good luck.
