Wheels
William Molina
im planning on getting 22x14 rims with a 36inch tires. Will I have any issues installing or driving with it with the stock air suspension?
1,226
325
You're going to need a lift kit, that's for sure.
22x14's and 36's are going to need more than your traditional lift kit. And with air suspension no less? Idk how it's going to work out.. need some seriously offset rims. A 6" lift that they don't make for the air suspension and then the rest of the factory suspension isn't going to be able to handle the stress
murrrphh
39
20
Check out customoffsets.com. If anyone is running that set up, I'll bet you can find it there. Would look sweet, that's for sure! Good luck!
Brokedownbutgood
289
103
35's fit with a 4 inch lift made by BDS suspension, but those wheels you mentioned don't belong on your truck. If you want that combo to fit get out the sawzall and plan on fixing stuff a lot.
1,226
325
