Will limp mode happen if driving without tune for EGR, Swirl Valve delete?
Jaski
Quick (hopefully) question;
Background first, I have a 2016 ED. Stock Everything, all updates done. Had the turbo coolant line failure under the intake manifold and its past all warranty extensions. So I did the fix myself with silicone heater hose (100 degree hotter rating than stock hose) While I was in there I wanted to do away with the stock manifold, EGR valve and such as the soot was quite caked in there. I am waiting on tuners to respond with options on deleting the "throttle body" and swirl valves, besides the EGR delete of course. I have also blocked off the EGR valve at the end of the tube on the EGR itself.
The question: While I wait, will the truck go into limp mode or be inoperable until I receive the tune? I don't care about a code being thrown or a CEL, I am just wondering if the truck will start, run and drive until I get a file from a tuner to work? I did not remove the DPF and will be running that till it fails as well.
726
In many cases it will eventually trigger some type of code relating rationale, you may be able to delete the code, but its only time before its triggered again, how many times before it starts the countdown to derated power I don't know.
Jaski
I wonder if I can just plug the sensors into the old intake and throw it in the bay somewhere haha
4,358
1,155
Those things are picky enough being plugged into a working unit much less a non working one :D
