5100&spacer
MRNY
34
Anyone run 5100 and spacer just saw a member on Facebook do this he has about 3.3 lift in front and wondering if what I want to do is possible. I want to use icons longer rear spring about 1inch raise in rear and in front use 5100 and a spacer and only adjust up to approx 3.7 give or take also new upper control arms what do u guys think?? Thanks Andrew
MRNY
34
Here's what the member told me I understand the ball joint and cv joint issues but maybe he found a way??? I'm running 22" x12" with 33". I have a 2" leveling kit in the front with bilstein adjustable front struts adjusted to about 3.5". I'm not 100% on offset but I didn't cut anything and it doesn't rub at all!
1,050
420
What does a 2" leveling 'kit' consist of? I've been under the impression that 5100s alone will level the front. No spacers or anything else needed.
MRNY
34
Your correct 5100 will level the truck but what if u want about 3.3-3.5 front lift and .5-1 inche rear then your less then 4inch lift but more then level
1,050
420
From what I've read (never lifted a Ram, only GMs TB front ends) anything above level in the front and you better go with a replacement UCA like Mevotechs or Zone.
MRNY
34
Oh yea am definitely getting new uca no matter what
