What brand did you go with?what is your addon aftermarket favorites? I added window vent visors, it gives that finished look and keeps the rain out.![]()
I'd really like to see and learn more about these Bilsteins.Mine would be the cap I just had installed. Has some issues with paint. But will get straightened out eventually.
I am really interested in the 5100 leveling shocks! Might be next?
They are great for these trucks. Widely used on the Ram 1500.I'd really like to see and learn more about these Bilsteins.
How do you like the Torque Pro app? Does it work well with the EcoDiesel?BAFX Bluetooth OBDI reader and Torque Pro app, Tyger Tonneau cover,
how does the shocks give you lift? no hardware like a leveling kit is needed?
Do you know any thing about aftermarket UCAs to correct the upper ball joint angles after a level?That's right. Just the shocks are all that's needed to level the truck. I'm not sure how it works but, it does. They are actually pretty popular. I learned about them just strolling through utube. They also make a set for the rear that can raise it up to an inch!
One on each corner could be a cheap small lift kit. And easily brought back to factory levels if you desired because it's all adjustable!
