Ecodiesel cranks but no start
Shorty9311
33
I have a 2015 ram Laramie ecodiesel. I was driving down the road and accelerated and the truck almost stalled. I got home and the truck will not start no. I checked the oil dipstick and it read minimum. I have no lights that popped up. And I have had the truck about 3 months so I don’t know when the fuel filter was last changed either. I don’t know if being low on oil would cause it not to start without a light popping up.
Shorty9311
33
Correction oil light is on at the bottom of screen. That would make it not crank
287
Welcome to the group put some oil in it 5/40 and try again check it for codes it can b various problems fuel reluctor ring crank sensor like I said check the codes
It's Rotella T6 5W40 and BTW the oil light is always on before starting the engine. I don't think that's your problem.
I'm going to guess there's a good chance it's the crank position sensor/reluctor wheel. This is one of the few issues that 50% of the time doesn't trigger a CEL (check engine light)
cds13ca
217
79
That was my initial thought too..., not a good problem to have. Very big job to chance a little part...
Shorty9311
33
Would that cause the truck to lose power when accelerating. Because i accelerated and then it down shifted and stayed at 3,000 rpm and wouldn’t go any higher. I had this problem with my 2011 mustang gt when I had it and it was due to low oil
cds13ca
217
79
Does it still run or just have no power? If the reluctor wheel has gone, it won't run. That's inside the transmission connecting to the back of the engine and it senses rotation, but the wheels starts to shred along the outside and then the truck doesn't sense it's even turning...
if it has no power, have you cleaned the map sensor and egr diffuser? Fuel filter should be changed every 2 oil changes. If the map is plugged it could lose power. What are the exact symptoms?
Shorty9311
33
I went to accelerate to go around somebody and it downshifted and then nose dived and stayed at about 3,000 rpm until I let off the pedal then it shifted up. I got home and checked the oil and it was reading minimum on the dipstick. I tried to start it about 10 minutes later and it was trying to start but didn’t turn over. I haven’t tried it since then I don’t want to break anything trying to start it until I change the oil. And it was almost time for an oil change to.
Shorty9311
33
I bought it from a ford dealership and they changed the oil before I bought it and they probably didn’t have the correct amount in it.
cds13ca
217
79
when is the last time the oil was changed? Who did the oil change?
cds13ca
217
79
did they use the correct type and quantity of oil... 10L exactly! Do it yourself, I wouldn't trust a ford mechanic working on a ram diesel...
Shorty9311
33
Yeah I know that’s what makes me think it’s the oil being low the ford mechanics did it before I bought it about 8,000 miles ago it time for an oil change. And I thought it was 10.5L of oil
727
You never Checked the lube in 8000 Miles on a new purchase... WOW...Back to your No Start, as mentioned tone ring one possibility another is the in tank lift Fuel PUMP , ED owners run their tanks down to empty and all that hot fuel dumps on the Pump form Injectors and Pump returns. Now if that engine is NOT starting due to NO Lube Your Bank account is going to be taking unexpected withdrawals $$$$$
Shorty9311
33
It’s been sitting for 7 hours and the dipstick is a little over the minimum line. I got all the stuff to do the oil change with I will notify tomorrow
727
If that's the Case it still should start. Changing the oil is 1 in 1 million to change a no start, Check the Fuel filter, generally when dirty engines loose performance, it still should start, UNLESS the fuel was contaminated and damage to the HPCR System causing No start.
727
Check the big main connection under the dash drivers side, That big connector if NOT perfectly matted will cause NO start.
Shorty9311
33
I checked all around for a fuel filter and nobody has one until tomorrow so I’m not wanting to take it off when I don’t have one. And I doubt it was even changed before I bought the truck from a ford place
