mileage between oil changes and do i really have to use euro
4,352
1,153
SLT
47
Oil change intervals are based on Duty cycle. Under severe operating conditions the monitor could say "Change Oil" as early as 3500 Mi./ 5600 Km. 10.000 Mi./ 16.000 Km is absolute Max!!!
My Dealer tells me they use Pennzoil Euro L 5W- 30, at $20.-/L, Mopar Filter $40.-.
If I get the Oil change done at the Dealership the Oil is $12.-/L , Filter $30.- , complete Oil change $240.-
So far I found Mobil 1 ESP for $ 17./L at Canadian Tire and a local Shell Dealer will bring in Pennzoil for about $70. for a 6 Pack.
Cheers, SLT.
1,266
346
The computer will never calculate a change based on duty cycle that's solely operator discretion. So be aware of what you're doing to your engine. Better safe than sorry. And Shop around for oils that meet spec. It can be had much less than the $200 dealer oil change. Mine run about 80 for oil then either a $30 mopar filter or a $10 aftermarket
SLT
47
I just posted about the Oil change interval because I have read in other Posts that the recommended Oil change interval is 10.000 Mi. or 16.000 Km. The Manual tells me that the Oil change Indicator will alert me when it is Time to change the Oil and it is based on the severity of service
like short distance driving, extended idling, towing etc.
For the type of driving I do ,I would never leave the Oil the Engine for 10.000 Mi./16.000 Km. On the other Hand, I do not want to change the Oil
to soon if not necessary. I'll decide when I get there.
Unfortunately I do not have many choices for the availability of different Oil because of where I live. The only two approved Oils I have found are the one I a local Store, Mobil 1 ESP and the one from the Shell Agent, Pennzoil Euro L. I'll order two 6 packs tomorrow from Shell.
4,352
1,153
Personally, no matter what 10K should be the max you run on the oil just because anything more and Ram could give you a hard time with warranty if you needed it.
If you run it hard, tow really heavy, and just run the crap out of the truck then I would probably think about changing it between 5K ~ 7K.
