Hi guy's me again, I've developed a new issue. Started engine and my engine warmer light remained on and blinks continuously service engine light came on. I already have an appointment for Thursday for recall but will this issue damage anything?
"Engine preheat" "Glow Plug" owners manual says squat. It suddenly remained lit and blinks. Service engine light came on. Checked battery connections all tight. Battery strength appears fine according to gauge, I'll hook up my volt meter later in the morning for confirmation. 12/8 I have an appointment for service, so back to my original question, could this damage something else prior to appointment.Glow plug light?
My only suggestion is to see what the trouble code is and post it. Did you ask the dealer if you can keep driving it?"Engine preheat" "Glow Plug" owners manual says squat. It suddenly remained lit and blinks. Service engine light came on. Checked battery connections all tight. Battery strength appears fine according to gauge, I'll hook up my volt meter later in the morning for confirmation. 12/8 I have an appointment for service, so back to my original question, could this damage something else prior to appointment.
I believe you have that backwards.My experience has been that if the Service Engine light is flashing then it is a "soft code" and vehicle can be driven without issue, however if the Service Engine light goes solid then the best recommendation is to have vehicle towed to dealer, as it may go into "limp home mode"
Dag nad it! John you are correct, I do have that backwards. My apologies. I had just finished reading the complete Class Action court filing and was a little aggravated. Thanks for the catch.I believe you have that backwards.
Good deal, and glad they were able to figure it out!Update, First service was completed and the problem has been diagnosed as a bad glow plug #4 to be exact. It's on order The dealership said I would be fine until the new part arrives being I keep the truck in a semi warm garage. I wish the same could be said for outside!
I still think were in our infancy with all this electronic gizmo stuff, I'm a stick and rudder guy myself it takes some getting use to....Good deal, and glad they were able to figure it out!
You wouldn't believe it but if I recall it is like a 12 hour job to do a glow plug as you have to drop the entire engine/lift the Body off of the frameUpdate, First service was completed and the problem has been diagnosed as a bad glow plug #4 to be exact. It's on order The dealership said I would be fine until the new part arrives being I keep the truck in a semi warm garage. I wish the same could be said for outside!
WOW!You wouldn't believe it but if I recall it is like a 12 hour job to do a glow plug as you have to drop the entire engine/lift the Body off of the frame
Good to hear!In shop at 7:15 out at noon, truck again running great.
maybe that's injectors? Looks like the glow plugs aren't terrible as long as they come out without much of a fight. Hopefully don't have to change too many glow plugs, damn things are at least $70 a pieceYou wouldn't believe it but if I recall it is like a 12 hour job to do a glow plug as you have to drop the entire engine/lift the Body off of the frame
Warranty work, but it's good to see now how long it will last.. I'm keeping the truck plugged in on a timer, first timer was made in China and didn't work worth a lick I returned it and got another. I decided to keep a ledger for the truck and document everything! It's going to be a balmy 32 degrees today, I'm going to attempt the Ionic step bars I picked up, provided the arthritis and body co-operate.maybe that's injectors? Looks like the glow plugs aren't terrible as long as they come out without much of a fight. Hopefully don't have to change too many glow plugs, damn things are at least $70 a piece
