Hello,
Does anyone know the standard oil change intervals for the EcoDiesel engine? I'm assuming 5K + miles correct?
does the display actually consider the condition of the oil or is it just a mileage counter8 qts of SAE 5W-20 every 10k mi max. According to the manual it could be as little as 3.5k under severe operating conditions. The display tells you when it thinks an oil change is needed.
Okay thank you, I had watched a U-2 video that said only the Ford system actually looked at the oil quality and the RAM just counted miles.Does the supply actually check the quality of the oil or just mileage can
